I made this funnel/clear tubing fill for the R18 Trans.Bought the items at Lowes.
I beveled/cut the tubing to make the fill less messy.
The tubing is a little tight but eliminates spill and the clear tubing allows you to see the fluid flow.I do like ability to put 150-200cc in and allow the air to escape.Again,No Spillage.
Removing the outer cover(1 screw) then remove the small box inside(not sure what it is, but 1 screw as well) allows better access.
