BeemeR18
- Discussion starter
- #41
Quick update on this issue, unfortunately still no luck.
The bike went to BMW Motorrad for around 2 hours of diagnostics/troubleshooting using ISTA. The main fault they've investigated was 3A1112 (Component Group 1 over-current) but surprisingly, their ISTA did not provide any more detail as to what the fault was (i.e. did not say 'fuel pressure sensor' or 'crank position sensor' whatever).
They followed the ISTA test plan, disconnecting the Group 1 components, but couldn't isolate the cause. I got the bike back with the same fault and no conclusive diagnosis.
Since I've already ordered the fuel pump, I did the following:
- Replaced the entire fuel pump assembly with a brand new unit (no change).
- Disconnected the fuel vent valve (no change).
- Disconnected all four O2 sensors (no change).
- Removed the fuel tank and disconnected the throttle body and fuel pump while inspecting the under-tank wiring loom. I couldn't find any obvious chafing or damage...
