www.dkdesign-global.com
I'll be ordering one of those beauties fo' sho!
...and my personalized version. Insert your text here! I'd probably put my actual license plate number on it if I got one.
DK Designs got back to me again:
"The Front Fender with White Pin Strips might be around $550+ Shippin.
We are still discussing with the paint shop. Currently is pre-order, or wait until we upload to our site.
For now, we have cylinder cover guards + breast plate in processing, will coming up pretty soon."
I told 'em again to let me know when they want the credit card info.
I also like the idea of a longer front fender but I’m put off with it being made from abs plastic.DK Designs got back to me again:
I told 'em again to let me know when they want the credit card info.![]()
That is a pretty large fender for all-ABS construction. The proverbial 'weakest link' is where it is bolted to the front forks. DK Design® knows this and have provided bolt-on bosses. These bosses need to be integral and larger to be worth the bother, though, like that evident on high-quality bolt-on carbon-fibre components - and carbon-fibre adds a fair amount more rigidity than ABS does. I suggest adding SS fender washers, inside and outside, when mounting the fender since the ABS will potentially flop around a bit in the wind, upfront - especially at higher speeds.I would also prefer a steel front fender, but I suspect that a steel version would be VERY expensive. If there's one thing that I've learned, even before taking possession of the R18, BMW parts are EXPENSIVE.
It will not be long before Russ Wernimont® and Klock Werks®, amongst others, offer proper steel front fenders for the R18, and most probably with different aesthetic options as well. And they sell for less than $400 typically for Haley Davidson - as premium a brand as BMW is.
I really want to like the DK Design® stuff, but their products seem rushed-to-market and un-engineered. ALL their R18 items feature integrity hiccups IMHO; that includes this fender, their engine guard (commented upon in another post), their skid-plate (sump-guard) and front axle sliders.
If you hit something solid with that skid-plate, like a protruding kerb-edge, the first points of failure are likely to be one or more aluminium bolt-bosses at the bottom of the R18 engine casing, where the DK Design® studs screw into. The skid-plate is also too low and does not feature openings for oil changes. I suggest using SS threaded-bar, instead of the substantial studs provided by DK Designs®, along with three SS nuts each, to set and adjust the skid-pan height. Trial-fit first to determine each threaded-bar piece's best length and then trim those to the required length. Threaded-bar will function as well as the DK Design® studs but will bend instead of leading to engine boss damage. A skid-plate for a road bike should be thin, contoured SS, like those commonly sold for Honda Goldwings, not a thick aluminium plate, like those fitted on Adventure bikes.
Front axle sliders should NOT expand into the ends of the front axle for two reasons; 1) not to impart any additional stresses into this (critical) hollow front axle (hoop stress in this instance) and 2) since axle sliders need to be tied together with a bespoke rod through the axle - if not, they will pop off instead of slide along. Once again, all form and little function. I suggest sitting it out till R&G® or Sato Racing® offer properly engineered equivalents.
First adopters almost always pay twice. And at times, substantially more. I know (-:
