I’m sorry, I don’t. I took one of my existing bolts to the local hardware store and matched up the diameter and thread pitch, then ordered from McMaster Carr. I assume you’ll need to order because I couldn’t find anything locally long enough with the correct pitch and full threads (no shoulder). The ones I found on line were just barely long enough. The threaded part of the bike frame is fairly thick, so I advise using some anti seize on the bolt. Looks to me like you could probably use a smaller diameter bolt with a shoulder, then finding one long enough wouldn’t be a problem. You could also drill out the frame and use a larger shoulder bolt. Either of these options would require using a backup wrench under the fender when you remove the bags. Just remembered, I’m running a luggage rack that the bolts have to pass through too, without the rack the bolts I found would have been the perfect length. Best of luck. Ross
