Cats and valves exposed
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1768230793#check"></use></svg></i> Discussion starter Discussion starter kate_brett
Post cut header pipe , diameter does diminish minimally before O2 sensor , then expands before Cat.
I have installed the Vance and Hines straight pipes on my FE but still not satisfied with the sound. How do I most easily access and remove the cats? I have done this on most of my bikes by just buying new headers but this does not look like an option with the R18.
On my previous R1200c, I bought exhaust pipes from Poland that had no cat. I'm at a loss as to what to do with my R18 since the cat is in the header pipe. That long drill is not something I would be comfortable using.
