Question Brake light wiring
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter DonC
DonC
Arroyo Grande
R18
I’m trying to install a ST2 brake light module. (It flashes the brake light if you slow by engine braking or downshift and don’t use the brakes). The instructions say to tap into the grey/red, grey/black, and brown wires. My rear lights have blue, brown, yellow, grey wires. (Grey and brown goes to the license plate light). Anyone know what color the power and signal wires are? (Brown is ground?)
Any info is appreciated.
