Aux fuel tank
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter fastring
fastring
2002 BMW K1200LT
Anyone installed one on a R18B or TC yet and can share how they plumbed the line into the tank?
None of the R18 variants come with an aux fuel tank. I can’t comment on aftermarket solutions that may exist out there, although this is the first time I hear about it. I think that Deleted member 939 installed a plastic fuel container in between the bike and the side car. Zoom in and you will see it next to the right saddle bag.
Thank you, Anibal. I see the plastic can now. The R18 with 6 gallon tank is only available on certain models. FYI - After market auxiliary tanks are custom and primarily used by crazy iron butt riders that want 300+ mile range. If anyone out there has any leads on auxiliary tanks for the R18 please respond to this thread. Thank you / Carl.
I Google searched the following, and found the below options:
"Overland Motorcycle Auxiliary Gas Tank"
Surprisenly ... RevZilla had options for motorcycles, and a couple other companies...
