agree. Hope someone can help. Few shorties have a descent heat shield.Looks kinda cool, I think
I saw in Australian R18 owners facebook forum, some members had made their own slip on exhausts by cutting 180 degree steel mandrel pipes. They looked and sounded pretty cool. This may be something like that. Wish I was that handy with steel!Looks kinda cool, I think
Bla bla bla …. “And the only way to know for sure unless it's really obvious is on a reliable Dyno.”I think the most torque you can get out of an exhaust system is a 2 into 1. None of the R18 s have that available even aftermarket that I know of.
Keep in mind that the longer pipes generate a reverb and back pressure needed for the most torque. When you start swapping out pipes you change the torque curve. What I have found is besides the looks and sound, you actually lose power with the shorter "cooler" looking pipes. Or, your off the line might improve very slightly, then at 2000 rpms or so it fizzles out. Seems like with a motor this size you want the max torque around 3500-3800 rpms.
This comes from maybe 100 hours over 10 years with various exhausts on a Dyno. But you find that funny???Bla bla bla …. “And the only way to know for sure unless it's really obvious is on a reliable Dyno.”
I agree. Most of us are cruiser type guys and don't actually care about a little bit of power loss in a certain rpm range.i always say I don't care and after I do it I usually think Damn why did I do that?? LolI think the most torque you can get out of an exhaust system is a 2 into 1. None of the R18 s have that available even aftermarket that I know of.
Years ago I didn't realize that the pipes can effect acceleration and overall how the bike runs. Then I got to be friends with a mechanic with a lot of experience who also had a Dyno that he made sure was calibrated to give accurate results. Then I started on a journey of having motors built, experimenting with lifters, cams, heads, exhausts.et.et.I agree. Most of us are cruiser type guys and don't actually care about a little bit of power loss in a certain rpm range.i always say I don't care and after I do it I usually think Damn why did I do that?? Lol
Yup.This comes from maybe 100 hours over 10 years with various exhausts on a Dyno. But you find that funny???
Respectfully, I have found experience to be FAR superior to opinions. You of course believe what you like...I have thousands and thousands of dollars and hundreds of hours screwing around with bikes that tells me different...Yup.
All the experience in the world means nothing without knowing the science of how something works.
Back pressure is a myth as it relates to modern engine performance; so 1970.
Back pressure is just additional work the engine has to overcome.
A little homework can go a long way if someone really wants to learn. Folks should google “ back pressure myths”. And/or “scouring velocity” .
Everyday is a school day.
I guess everyday is not a school day.Respectfully, I have found experience to be FAR superior to opinions. You of course believe what you like...I have thousands and thousands of dollars and hundreds of hours screwing around with bikes that tells me different...
BTW if you notice at some airports that have huge backwalls placed where the jets take off....why??? Back pressure. It's a different dynamic....but a related principle.
But anyway....no matter....I'm sure you’re right.....
2 into 1 was always the best. At least when I had Harley-Davidsons. And they bark!I think the most torque you can get out of an exhaust system is a 2 into 1. None of the R18 s have that available even aftermarket that I know of.
2 into 1 ‘generally’ increases scavenging and increases exhaust flows. (The exact opposite of back pressure). But it’s not always the case. And many times the gains are not material. Some people really like the look.2 into 1 was always the best. At least when I had Harley-Davidsons. And they bark!
