Question 2023 TC Tubeless or Tubed?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter insider
insider
CA
R18B
Hi all, newbie to the R18 platform. I was poking around Max BMW's microfiche and saw that there's a part number for an inner tube....
So I have a 2023 TC with these wheels. Are these style stock wheel tubeless compatible? Is it already tubeless? (Clearly, there's a TPMS sensor.)
The Michelin tires seems to indicate Tubeless compatible...
Sry for being a noob... 😅
The r18B and TC are tubeless. I believe the R18's with spoked wheels have tubes.
Ride on! I'm about to do some longer road trips and building up a tool kit.
I can plug a tubeless tire like a mofo (trick to pack a small hobby bar clamp to help push the plug into the puncture) , but tubed... well that's a whole to do...
Thank you!
