Service Warning Light
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Grasshopper
How does one cancel the Service Warning Light? I just had all the oils done and the light stays on. It wasn't done at a dealer.
The only way to reset the service indicator is to have the dealer do it or purchase a GS911 tuner or a Motoscan app (Android Only) for your phone with an OBDII bluetooth adaptor and reset it yourself.
Repost of something I posted in a similar thread:
"I bought one of these to reset my MX light: https://www.cgsulitstore.com/produc...-tool-motorrad-obd2-scanner-cgsulit-sc530-pro
Relatively cheap ($139), easy to use, doesn’t require Bluetooth or internet. Plug it in to the OBD port and the bike battery powers the unit. No licenses to buy. Does everything a garage mechanic could want. Reads codes, resets codes, etc. No limit to the number of times you can use it per VIN. It also didn’t interfere with my Bren Tune. I looked at the GS911 about a year ago and it seemed ridiculously cumbersome to set up and use and expensive for what it is. The Motoscan solution seemed equally cumbersome. Because of the cost and the hassle I’ve just been riding the bike with the idiot light on. When I discovered this unit I figured it was worth $139 to give it a try. So far so good. This CGSULIT unit I bought was a 1/3 the price and much simpler to use. Just plug it in to use it. Highly recommend. It is a BMW specific reader. Won’t work on other bikes but they have models specific to other brands."
That does look really handy ... no phone and /or tablet needed ... can it do additional things like enable/disable cruising lights ... enable/disable additional driving lights ... maintenance reset ... speed limiter/rev limiter? ... just curious, I own a GS-911 and am very happy with it ... but a hand held unit would be nice to keep in the bags on trips ...
I don't know about enabling/disabling lights or speed limiters. It may or may not do those things but they're not something I'm interested in. I bought it to reset the mx interval and get rid of the idiot light. It does read codes though and if I do get an idiot light I can at least look and see what's going on. IMO it was worth $139 to save me from a dealer visit to reset the light/service interval. It only took one time to pay for itself.
I bought the Unicarscan UCSI-2100 Bluetooth OBD2 Adapter and used the BikerTune app (I'm an Android user but I believe it works on Apple IOS too), the adapter was about £58 and the app was either £12 or £14 to unlock the full license. Took longer to remove the side panel and get to the OBD port than it did to do the reset. Worked a treat!
