Alert 2022 Mars Red bobber - new owner!
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter cheeseBagger
cheeseBagger
Cola, SC
r1200c
I will send pics and info asap, but have a question: buying a slightly used '22 model. Do they usually come with 2 key fobs?
Thanks in advance, pretty excited here . . .
Yup same here 2021 FE only came with 1 FOB and a plastic emergency key that has NFC capabilities and can be used to start the bike (pain in the rear though)
My friend lost his key to his TC and I think it cost him like $650 to get a new one. So, you can have two, but it will cost you some cabbage.
At least here in UK are some boys with vans which are coming at your home and are making you a perfect working key on the moment, chip programming and is going to cost about half of the price I mean about 300GBP, maybe less but not to much!
The moral of the story do not lose it !!!! Also on my 2022 classic the emergency key does not work unless you take the seat off !!!!!!! because i changed the stock seat for a Corbin gunfighter for some strange reason the signal is not received , this was verified by the dealership !!!!!!!
