Buzzing noise from battery area
Folks I need your help.
Got a 21 FE with 2800 miles.
Starts stops and runs just fine, reverse even works.
Problem is a noise from around the battery area. When shifting into first or second there is a weird buzzing noise for a few seconds.
BMW don't yet know what it is, just that it's thankfully not the gearbox.
All thoughts or solutions are welcome
Thanks
Thanks
I had the same problem. The Service Bulletin solved the noise. Call you dealer and ask the service dept. to look up.
BMW R18
PUMA - Service Bulletin
S1 13 07 21
Loud / Noisy Fuel Pump
Reply
Enzo5000,
Thank you for your reply and Service Bulletin.
Greatly appreciated, I have sent it to my dealer.
Can you recall if it was software fix or a new fuel pump.
Thanks again
